8 Distributing Configuration
Prerequisites for Distributing Configuration
Approved configuration can be distributed once a custom template is associated to properties. SeeAssigning Properties to Custom Templates for more information.
Initiating Distribution
From the Side menu, select Manage Custom Template.
Select the custom template in the search result, then click Manage
Select Distribute.
Exclude Previously Distributed: Select check box to only include new records.
Search and select properties from the list.
Click Distribute.
Viewing Distribution Job Status
To display a list of all distribution jobs and their status.
From the Side menu, select Manage Distribute Jobs.
Enter search criteria and click Search.
Click View Logs
for any job in the search result to display detailed information. See Viewing
Distribution Logs for more information.
Related Topics
