9 Manage User Groups
Prerequisites for Managing User Groups (Roles)
A list of all enterprise-level groups created in OPERA Cloud Identity Management (OCIM) are displayed.
The following (read only) groups are seeded:
<ENTERPRISEID>-ADMIN is assigned the Manage Groups and Enterprise Settings tasks in order for an administrator to assign tasks to custom user groups you configure.
<ENTERPRISEID>-ENTDATAACCESS and <ENTERPRISEID>-ENTSENSITIVEDATAACCESS are used by Oracle support for support access.
Editing User Groups
Tip:
Click Refresh to update the result.
You can manage groups by providing sub tasks and access to main tasks at Configuration group level.
From the Side menu, select Manage Groups.
Select the user group in the search result, then click Edit
Enter search criteria, then click Search .
Select a Task Group, then select tasks to assign or click the Select All checkbox to select all tasks in the task group.
Repeat steps for other task groups.
Click Save.
