7 Using Data Import
Use data import to populate (seed) an Enterprise Template with all configuration from an OPERA Cloud property (OPERA mode) or import selected configuration details from CSV templates to Enterprise or Custom Templates (all modes).
Importing Configuration from OPERA Cloud
In OPERA mode you can populate all configuration types from an OPERA Cloud property to an unconfigured (blank) Enterprise Template. The configuration is imported in Pending status. The import includes Template Roles.
Does not include OPERA Controls.Tip:
Remember to assign the enterprise template task to a user group assigned to your user.
From the Side menu, select Manage Imports Jobs.
Click Create.
Select OPERA Cloud Import and complete the following:
Select the Enterprise Template to import to.
Select the OPERA Cloud Property to import from.
Job Description: Enter a job description. Defaults to 'Import from <property> to <template>'.
Click Create.
Importing Configuration from CSV Templates
You can selectively import configuration entries and template roles to Enterprise or Custom Templates.
Start by downloading the CSV templates for each configuration type, then prepare the data using Microsoft Excel or similar solution. To setup Template Property Roles, use the TEMPLATE_ROLES_1.CSV file and enter Y or N in the E column for each task listed. Seeded Report Group tasks are included in TEMPLATE_ROLES_1.CSV and can be imported with the Template Property Role. Tasks created for customer-defined Report Groups are not included in the downloaded CSV and must be assigned to the Template Property Role after import.
Row 2 in each CSV file indicates the data type, string lengths, date format and other important information; this row is ignored on import.Downloading Templates for CSV Import
Each CSV data file must have a maximum file size of 2MB, and you can import multiple files for one template (uniquely name each file. For example, Market_Codes01.csv and Market_Codes02.csv).
Click Download Template to download the ConfigurationCSVFiles.zip file.
Navigate to the download folder then unzip the ConfigurationCSVFiles.zip file.
Open and prepare data for each of the configuration CSV files.
Creating Import Jobs
The enterprise template(s), custom templates and configuration options displayed are based on the tasks assigned to your role. See Manage User Groups for more information.
Tip:
Click Refresh to refresh the results updated status of Job ID(s).
Click Create.
Select CSV Import and complete the following:
Select Template: Select the template from the list (both Enterprise and Custom templates are listed).
Configuration Type: Select a configuration type from the list.
Click Attach File and select the CSV file to import or drag the CSV file onto the area.
Repeat for additional files to import.
Click Create.
Deleting Import Job
You can delete jobs when Status is New.
From the Side Menu select Manage Import Jobs.
Enter search criteria.
Select the job in the search result, then click Delete
