Block Management
Block management involves the organization and administration of group reservations or blocks of rooms in a hotel. This process in OPERA Cloud includes setting aside rooms for events, conferences, or group bookings, ensuring availability, and managing associated logistics and billing. You can retrieve block allocations to manage group reservations and optimize room inventory. This data helps in dynamic pricing adjustments and accurate forecasting for better revenue management in OPERA Cloud.
Figure 4-3 Workflow
Use Cases
| Use Case | Description | Operation |
| Retrieve details about your block allocations | You can fetch block allocation information for a hotel within a specified date range. This returns details about the allocated inventory, rates, and room type statistics, aiding in the management of group reservations and optimization of room inventory. | getBlockAllocationSummary |
Retrieve Block Allocations Summary Data using getBlockAllocationSummary
The asynchronous operation getBlockAllocationSummary can be used to retrieve detailed information about room block allocations. This information includes the number of rooms allocated, block dates, and associated rates, which are crucial for managing group reservations and optimizing room inventory. The data can be utilized for dynamic pricing adjustments, accurate forecasting, and effective revenue management.
| Business Logic | Comments |
| Retrieving the initial block allocations summary data using start/endDate |
The block allocation summary data can be requested using startDate and endDate to fetch the initial block allocations summary data for a specified date range:
Other Critical Parameters include:
| Retrieving the incremental block allocations summary Data using startLastModifiedDate/endLastModifiedDate |
The block summary data can be requested using startLastModifiedDate/endLastModifiedDate to fetch the reservation summary data for a given date range:
| Key Considerations |
| Key Response Data Elements |
The key response data elements include the following:
| Sample API request/response |
startBlockAllocationSummaryProcess (startDate/endDate) 1.2. startBlockAllocationSummaryProcess (requested using the parameters startLastModifiedDate/endLastModifiedDate) startBlockAllocationSummaryProcess (startLastModifiedDate/endLastModifiedDate) 2. getBlockAllocationSummaryProcessStatus getBlockAllocationSummaryProcessStatus 3. getBlockAllocationSummary getBlockAllocationSummary |
Parent topic: RMS Use Cases
