4 RMS Use Cases
Workflow Overview
There are two main types of RMS Data flows:
Initial data load/sync:
Fetching the relevant data for your revenue management system using business events or APIs that can act as a base/snapshot for your analysis. For example, you can fetch bulk reservation and block and inventory data to get started with your analysis.
Figure 4-1 Initial Data Load/Sync Workflow
Daily data collection and update:
Utilize this flow for your day-to-day workflow to fetch/update incremental data in OPERA Cloud. For example, you can only fetch the updated reservations from the system This also helps to limit the number of requests on your RMS and OPERA Cloud.
Figure 4-2 Daily Data Collection and Update Workflow
