10 Limits
To ensure operational efficiency of hotel customers, various limits are in effect.
Number of Applications
The maximum number of applications that can be registered in the OHIP Developer portal is 100.
Streaming
Throttling
The Streaming API itself is not throttled. However, to maintain a stable and reliable service, OHIP enforces limits on incoming HTTP API requests that are used to manage or interact with a stream.
- Up to 12 requests per minute are allowed.
- Short-term bursts of up to 100 requests per minute are permitted.
Only One Consuming Client
Only one client can be connected to consume events from a single chain in a single gateway on a single application key.
To create a scalable consuming architecture, see Streaming Best Practices.
Consuming Limits
It is expected that streaming consumers remain connected at all times. In the event of a disconnection, it is vital that the consumer connects to the WebSocket at least once every 24 hours. If not, then you must send the optional "offset" input parameter together with the value of the last offset you received.
Ensure there is a minimum of 10000ms (10 seconds) between sending the "complete" message to close one WebSocket connection and sending the next "subscribe" message to reopen a WebSocket connection.
For more information on consuming limits, see Streaming Best Practices.
Headers
The total size of all HTTP headers is 8KB. This includes the oAuth token, application key, x-request-id, and all other headers.
API Throttling
To ensure stable and reliable service for all customers, the Hospitality Integration Platform enforces limits on the rate of incoming API requests.
- Up to 50 requests per second are allowed per environment.
- A short-term burst of up to 100 requests may be permitted per environment.
If your integration exceeds the standard rate limit, additional requests within that second may be automatically delayed. Each request above the limit will experience a small, additional delay, helping to spread out the traffic and avoid overwhelming the platform.
If your system sends a very high number of requests in a short burst that exceeds the burst threshold, requests beyond this limit may be immediately rejected with an HTTP 429 ("Too Many Requests") response.
These limits are designed to protect ongoing hotel operations and to ensure all customers receive reliable service. Oracle may adjust these thresholds as needed to maintain service quality and will provide advance notification of changes whenever possible.
For Shop and Book related calls, consider Distribution APIs (see Oracle Hospitality Distribution APIs for more information).
Retrieve more coarse grained data in a single call rather than performing filtering in the client.
Reduce the frequency of calls.
Cache data that changes infrequently, such as Lists of Values.
Review the API release notes for new operations that could reduce the frequency of API calls (for example, asynchronous (jobbed) operations).
Consider the Streaming API as an alternative to the Polling API (pull).
Requests per Second
getBusinessEvents
getBusinessEventsByExternalSystem
Asynchronous APIs allow a maximum of 100 requests per minute for POST, 300 requests per minute for HEAD, and 300 requests per minute for GET for each environment.
oAuth Token Lifetime
Our recommendation is to request a token when the current token will expire in 1 minute and implement code that caches and automatically renews the token (when the token's lifetime is down to 1 minute) and stores it securely. Code that makes API calls can then use the cached token and be assured it is always valid.
Ensure that the code looks at the "exp" attribute of the oAuth token to determine when the token will expire.
Request Body Size
The maximum request body size is 100KB.
In the Property API Price Availability Rate Async, the operation:
postRestrictionsProcess
In the Property API Block, the operations:
postRoomingList
postSubAllocation
putBlockAllocation
In the Property API Reservation, the operations:
postReservation
postReservationByBlock
In the Property API Rate Plan Asynchronous Service, the operation:
startSetDailyRatePlanSchedulesProcess
In the Property API Inventory Asynchronous, the operation:
postSellLimitsProcess
In the Property API Content Service, the operations:
emailFolioReport
setCustomizedLetter
In the Property API OPI Token Exchange Service, the operation:
openPaymentTokenExchange
uploadFileAttachment
uploadImage
Pagination Limits
Most Property APIs are paginated, meaning they return only one page of data at a time. The maximum size of the page is defined by limits documented both in the API specifications and in Property REST API Get Query Parameter Limits.
Asynchronous APIs
Asynchronous APIs allow a maximum of 250 requests per minute for each application per environment for POST requests.
Since they process data in bulk, the Asynchronous APIs have additional restrictions. A full matrix of these are available in Types and Usage Recommendations, but these are repeated below:
Identical Requests
To avoid duplicate requests, every identical request (employing the same query parameters) necessitates a mandatory 30-minute interval between submissions. Note that this limit applies regardless of whether the POST, HEAD, and GET cycle has been completed.
In the Property API Block Reservation Asynchronous, identical requests to the operation startBlockAllocationSummaryProcess (when used with startLastModifiedDate/endLastModifiedDate) must be spaced 3 hours apart. Note that this limit only applies to identical POST requests made without completing the entire POST, HEAD, and GET cycle.
In the Property API Reservation Asynchronous, in the operation startReservationsDailySummaryProcess, identical requests to the operation startBlockAllocationSummaryProcess (when used with startLastModifiedDate/endLastModifiedDate) must be spaced 3 hours apart. Note that this limit only applies to identical POST requests made without completing the entire POST, HEAD, and GET cycle.
In the Property API Block Reservation Asynchronous, the operation startBlockAllocationSummaryProcess is used with startLastModifiedDate/endLastModifiedDate.
Maximum Date Ranges
Synchronous APIs
Several Property APIs have a maximum date range. These restrictions are listed in the API specifications as well as in Property REST API Get Query Parameter Limits.
Asynchronous APIs
In the Property API Inventory Asynchronous, the operation startRevenueInventoryStatisticsProcess has a maximum date range of 400 days. For OPERA version specific restrictions, refer to Types and Usage Recommendations.
In the Property API Block Reservation Asynchronous, the operation startBlockAllocationSummaryProcess has a maximum date range of 94 days. However, when requesting data with startLastModifiedDate/endLastModifiedDate, the maximum date range allowed per request is 3 days.
In the Property API Reservation Asynchronous, the operation startReservationsDailySummaryProcess has a maximum date range of 94 days.
In the Property API Rate Plan Asynchronous Service, the operation startSetDailyRatePlanSchedulesProcess allows rate plans to be defined for up to 365 days.
Length Restrictions and Multi-byte Characters
"addressLine": {
"description": "When the address is unformatted (FormattedInd=\"false\") these lines
will contain free form address details. When the address is formatted and street number
and street name must be sent independently, the street number will be sent using
StreetNmbr, and the street name will be sent in the first AddressLine occurrence.",
"type": "array",
"maxItems": 4,
"items": {
"type": "string",
"minLength": 0,
"maxLength": 80
}The 80 characters of this restriction implies 80 ASCII characters. Many UTF-8 characters are multi-byte. A multi-byte character takes up more than one ASCII character, so fewer than 80 multi-byte characters will fit into the "addressLine" field.
Consumers sending multi-byte characters must ensure the ASCII equivalent length of the data does not exceed the published length restrictions.
Data APIs
- In each query, a maximum of 1,000,000 (1 million) rows (or records) can be fetched. Make multiple requests if more than 1 million rows are required.
- In each query, a maximum of 1GB of data can be fetched. Make multiple requests if more than 1Gb of data is required to be fetched.
- For date range input parameters, a maximum of 730 days (2 years) can be queried.
- For date input parameters, if a list of specific dates is sent, a maximum of 100 dates are allowed in each request.
- In each request, a maximum of 150 fields (data points) can be requested for each Subject Area. Make multiple requests if more than 150 fields are required.
- A maximum of 10 concurrent requests can be made at any time for each R&A instance.
- Connections last a maximum of 30 minutes. This means that responses will be streamed during a maximum period of 30 minutes. If additional time is required to fetch all the data, a new request is needed with adjusted input parameters.
- A minimum of network bandwidth of 100 Mbps.
IP Allow Listing
You can configure a maximum of 100 IP ranges per chain.
