October 2025 ReadMe
Overview
This document contains a list of upcoming major changes to Oracle Hospitality APIs.
| What will Change | Details of the Change | Target Product and Version | Impact | Call to Action |
The data included in the Business Event payload of the Streaming API will be now be dictated by what triggers are configured in the OHIP Developer Portal. Previously, ALL data elements were included in the "detail" array of the Business Event payload. |
New features available in OHIP 25.4 will mean that business events consumed via the streaming API must have triggers defined for them. Triggers can be defined in the OHIP Developer Portal. A trigger is a business data element such as LastName. If an UPDATE PROFILE event is subscribed and the trigger LastName is configured, then a Business Event notification will be sent only when the LastName field changes. This is the same functionality as the polling API which is configured in OPERA Cloud. With OHIP 25.4, when a Business Event is sent by the Streaming API, only the Data Elements explicitly configured as triggers for that event in the OHIP Developer Portal will be included in the "detail" array of the Business Event payload. Data elements that have not been selected will no longer be transmitted, even if they are updated within OPERA Cloud. This change is being introduced to improve performance, efficiency, and system stability by reducing unnecessary data transmission. |
OHIP version 25.4 |
Existing subscriptions will only be affected if the event configuration is changed in the OHIP Developer Portal; until then, they will receive all data elements. New events being configured and existing events being edited in the OHIP Developer Portal must select triggers, and will receive only the data elements in the payload that match the triggers. Integrations that rely on receiving all data elements in the
Streaming Business Event payloads may experience incomplete
data when editing existing configuration or subscribing to a
new environment in the OHIP Developer Portal.If not adjusted
integrations will be affected:
Adapt Integration Logic: Ensure your integration can handle payloads with variable data elements depending on the configuration. Add Orchestration: Orchestrate such that when you receive a Business Event notification you look at the primaryKey and send an API call to obtain the latest version of that resource using the primaryKey. This has the added benefit that the API call will return the full resource and child elements, whereas the Business Event notification includes only the header of the resource. Once the change is live If not orchestrating and you require a small number of data elements, use the OHIP Developer Portal to ensure these are selected for all subscribed events and all subscribed environments. |
This change applies only to Base Rate code types that have a Standard Rate linked to them. Currently, the operations postRatePlan, putRatePlan, postRatePlanSchedules, and putRatePlanSchedules are used for creating and updating rate plan headers and pricing schedules. When the parent Standard Rate code has a large number of
pricing schedules (1000+), or is linked to a high number of
Base Rate codes (75+), you must now use the additional ASYNC
process APIs:
These new ASYNC process APIs work alongside the existing operations to ensure proper processing and synchronization of pricing schedules in these large or complex scenarios. |
These changes ensure pricing schedules are accurately processed and synced at scale. |
OPERA Cloud 25.5 | If not adopted, pricing schedules will not be processed to the dependent base rates for large volumes. |
Prepare Now
| The “membershipLevel” field is now mandatory in the postMembership operation. |
To align the API with the OPERA Cloud user interface, the postMembership operation now requires the membershipLevel attribute to be able to create a membership. |
OPERA Cloud 25.3 |
API calls to postMembership will fail if the request body does not include the membershipLevel field. |
If calling the postMembership operation, ensure code always sends the membershipLevel attribute. |
