21 Upcoming Major Changes
This topic applies to Customers, Partners, and Support Agents of Oracle Hospitality Integration Platform/Oracle Hospitality Integration Cloud Service.
As part of the continuous delivery model for Cloud Service, APIs, features, and technical components of a solution may be removed, changed or replaced to enhance the security, performance, and overall quality of the Cloud Service. When this occurs, the deprecation or change of an API or component will be announced in advance, allowing customers sufficient time to anticipate the change and transition to any enhanced API or replacement feature/component. After the change is announced, the API change, deprecated feature, or component will remain in the solution until the planned removal date.
The following is intended to outline our general product direction. It is intended for information purposes only, and may not be incorporated into any contact. It is not a commitment to deliver any material, code, or functionality, and should not be relied upon in making purchasing decisions. The development, release, and timing of any feature described for Oracle's product remains at the sole discretion of Oracle.
| Announcement Date | Link to ReadMe | Additional Information | Comments |
23-June-2026 |
4-February-2026 |
27-October-2025 |
10-Jun-2025 |
17-March-2025 |
9-Sept-2024 |
15-July-2024 |
21-May-2024 |
30-Apr-2024 |
25-Sep-2023 |
