May 2024 ReadMe
Overview
This document contains a list of upcoming major changes to Oracle Hospitality APIs.
| What will Change | Details of the Change | Target Product and Version | Impact | Call to Action | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Event resources will enforce a minimum of zero attendees. |
The following operations will enforce a minimum of zero attendees: postEvents getEvent changeEvents changeEventsResourcesByChain getEventsResources changeEventsResources getEventResourceByMenu changeEventResourceByMenu getEventItemSplitQuantity getCateringPackages changeCateringPackages getWaitlistedEvents manageWaitlistedEvents In the following properties: Expected, Guaranteed, Billed, Actual, Set, Package Expected, Package Guaranteed, Package Billed and Package Actual Attendees. |
Oracle Hospitality OPERA Cloud 24.3 |
If a negative number of attendees is supplied, the call will fail with a 400 HTTP status error response. |
Ensure that a positive number of attendees is supplied to these operations. |
Enhancing error response bodies. |
The error response body will be enhanced in the following operations. Note that the HTTP response codes are not changing.
Oracle Hospitality OPERA Cloud 24.4 |
If the body of error responses is parsed, this could result in failures or miscounts. |
Alter integrations that branch based upon the error response body to be built on the HTTP response code. Utilize the enhanced error response bodies to guide development work. |
Promotion of Oracle Hospitality Distribution v0 APIs to v1. Deprecation of v0 Oracle Hospitality Distribution APIs. |
Oracle Hospitality Distribution APIs are currently available only as /v0. All operations will now be v1 with v0 APIs deprecated in 12 months’ time. All v0 APIs will be removed. |
Oracle Hospitality Integration Platform 24.2 |
When the v0 Oracle Hospitality Distribution APIs are removed, calls with /v0 in the URL will fail. |
Change /v0 to /v1 in the URI of every API call to an Oracle Hospitality Distribution API. |
