Managing Client Applications
Starting with OHIP Portal version 25.3.1, newly created clients are in a human-readable format '<chain><enterprise><environment><clientName>' rather than a GUID (for example, 'a995b6b2-c983-11ee-8c2e-0242ac110002'). This makes it easier to see who made changes when hotels look in audit logs. The clientName is the same as the clientId to help customers auditing records in OCIM.
Starting with OHIP Portal version 25.5.0 and OPERA Cloud version 25.4.0.0 or higher, OHIP Client IDs can be up to 100 characters long. If the OPERA Cloud version is lower than 25.4.0.0, client IDs can only be up to 50 characters.
With OCIM, you can create multiple clients for different integration needs. This is aimed at providing enhanced security as each integration can have its own client based authentication. Please note this feature is available only for OCIM enabled customers. Partners will continue to have a single client application for a given customer environment.  The following sections explain how to manage client applications in a customer environment.
A default client is already created and can be used for all integrations if that is the customer’s preference.
Searching Client Applications
To find the client applications associated with an environment:
  1. From the Developer Portal, click Environments at the top of the page.
  2. Click the View Details link for the environment you want to view.
  3. This will list all the client applications that have been created for the environment.
  4. Search for a given client by Client ID or Client Name in the search bar to find a client.
Adding New Client Applications
To add a new client application:
  3. Click the Add Client button.
  4. Provide the name of the client. This name is unique across all the clients created with the enterprise.
  5. Click Next.
  6. If Module Level Access Control is enabled for your organization, select the OPERA modules that the client application can access. You can use the search field to find specific modules.
    1. If only certain functional areas are required you can drill down from modules to functional areas and select only the required functional areas.
    2. In case a functional area has operations belonging to multiple functional areas, the associated functional areas will automatically be selected with the given functional area.
    3. To request access to certain sensitive data elements, such as identity document IDs and dates of birth in API responses, select Grant Sensitive Data Access.
      This does not allow access to highly restricted information such as credit card numbers.
  7. Click Next.
  8. Search for and select the properties you want to assign to the client.
  9. Click Next.
  10. Review the Summary and then click Add.
  11. Once the status of the client is in Approved state, the client is ready for integration.
Cloning Client Applications
To clone a client applications associated with an environment:
  3. Search for the client by Client ID or Client Name in the search bar to find a client.
  4. Click the ellipsis button under the Actions column.
  5. Click Clone.
  6. Enter a new name for the client.
  7. Click the Clone button.
    This clones the configuration of the existing client into the new client.
The Client ID and secret are regenerated and must be copied for the new client. See ‘Issuing Client Secrets’ above for more about managing the client secret associated with the client application.
Deleting Client Applications
To delete a client application associated with an environment:
  4. Click on the ellipsis button under the Actions column
  5. Click the Delete button.
    This will delete all the configurations for the client
All existing integrations using the client must be updated with another valid client application.
To change the properties a client application can access:
  3. Search for the client by Client ID or Client Name in the search bar.
  5. Click Manage.
  6. In the Assigned Details section, click Edit.
  7. If Module Level Access Control is enabled for your organization, select or update the OPERA modules that the client application can access. You can use the search field to find specific modules.
  8. Select the new list of hotels the client application may access.
  9. Click Update.
