Managing Partner Connections
Starting with OHIP Portal version 25.3.1, newly created clients are in a human-readable format '<chain><enterprise><environment><clientName>' rather than a GUID (for example, 'a995b6b2-c983-11ee-8c2e-0242ac110002'). This makes it easier to see who made changes when hotels look in audit logs. The clientName is the same as the clientId to help customers auditing records in OCIM.
For customer environments supporting a Client Credentials authentication scheme (OCIM), the partner connection requests take place in the OHIP (Partner) Developer Portal and approvals take place within the OHIP (Customer) developer portal.
When Module Level Access Control is enabled for an environment, partner environment access requests may include requested OPERA modules, functional areas, and Sensitive Data Access.
Before approving the partner connection request, customer administrators should review the requested modules and functional areas to confirm that the partner requires the requested access for the intended integration.
If the partner requests Sensitive Data Access, customer administrators should carefully review the request before approving it. Sensitive data, such as identity document IDs and dates of birth, may require special handling under applicable global privacy and data protection regulations. Customers may wish to seek assurances from the partner that sensitive data will be handled appropriately and in accordance with applicable privacy and data protection requirements.
If a partner later changes the requested Module Level Access Control permissions, including module access, functional-area access, or Sensitive Data Access, the customer must review and approve the updated request before the changed permissions are granted.
Approving Partner Connections
When a partner submits a new request to add a customer environment, an email notification is sent to all the chain administrators informing them about the new connection. Follow the below steps in the OHIP customer portal to approve the partner’s connection request.
  1. From the Developer Portal, click Environments at the top of the page.
  2. Click Partner Connections. All the partner connections appear in this section.
  3. Search for the partner connection that is pending approval.
  4. Search for and select the properties you wish to assign for the partner connection.
    After receiving the approval email, wait 5 minutes before calling the environment. You may see more than one environment card appear as Pending Approval.
  5. Click Next.
  6. Once you have reviewed the Summary, click Approve to approve the partner connection request. The status of the partner connection request should change to “Approved” in both the customer and partner portal.
  7. An email notification is sent to the partners informing them about the approval of the connection request.
Rejecting Partner Connections
When a partner submits a new request to add a customer environment, follow the below steps in the OHIP customer portal to reject the partner’s connection request.
  4. Click Reject to reject the partner connection request. The status of the partner connection request should change to “Rejected” in the Environment section of both the customer and partner portal.
    An email notification is sent to the partners informing them about the rejection of the connection request.
Revoking Partner Connections
To revoke access to approved partner connections:
  3. Search for the partner connection that is already approved.
  4. Click Revoke Access to revoke the access of the partner connection. The status of the partner connection request should change to “Rejected” in the Environment section of both the customer and partner portal.
    An email notification is sent to the partners informing them that their access is revoked.
Editing Partner Connections
To edit an approved partner connection:
  4. Click View Details.
  5. In the Assigned Details section, click Edit.
  6. Select the hotels the partner connection may access and then click Update.
The partner can see the updated list of hotels in the developer portal.
Suspending a Partner Connection
If a partner connection is Suspended:
  • The customer developer portal displays the partner's integration as 'SUSPENDED' in both the streaming approvals and OCIM approvals sections.
  • The developer portal shows a 'SUSPENDED' status label as appropriate.
  • The partner is unable to call APIs or consume Business Events. Any solution the partner offered by consuming the APIs would not work.
  • If you have questions about the 'SUSPENDED' status of the partner, contact your partner.
