Removing an Environment
Prerequisites for Removing an Environment
  • Only partners can remove an environment. Customers can by default view their environments. For more information, see Viewing Environment Details.
  • When you remove an environment, it will cease sending any events to which you have subscribed via the streaming API.
  • You can add back the environment, but it will be subject to the customer's approval.
  • If you add back an environment, you must use the same enterprise ID and chain code that was previously used to add the environment.
  1. From the Developer Portal, click Environments at the top of the page. All your environments appear on this page.
  2. Click the View Details link for the environment you want to remove.
  3. Click Remove Environment and click Remove to confirm.
    The following message appears when you click Remove Environment:
    “Are you sure you want to remove this [Environment_Name] environment?
    You can add the environment again, and it will be subject to customer's approval.”
