8 Migrating to the Client Credentials (OCIM) Authentication Scheme
Follow the below steps only for environments that are migrating from a resource owner group (Shared Security Domain - SSD) authentication scheme to a client credentials authentication scheme (OPERA Cloud Identity Management - OCIM).
What is OCIM and why is Oracle moving to it?
OCIM is a cloud-ready identity and access management service for OPERA Cloud. OCIM replaces SSD as the core identity and access management engine for OPERA Cloud, thereby, increasing security and making managing integrations easier. In OCIM, each chain belongs to an enterprise with an enterpriseId.
Migration Notification and Brief Downtime
Oracle will notify customers and their integration partners well in advance of migration dates. This ensures all stakeholders can adequately prepare for the migration.
Overview
Oracle is migrating one OPERA Cloud environment at a time to OCIM.
Customers and partners who call APIs through the Oracle Hospitality Integration Platform (OHIP) authenticate using an OAuth token. In SSD, this relies on an integration user’s username and password; this is called the “resource owner” flow. In OCIM, this relies on a ClientId and ClientSecret; this is called the “client credentials” flow. This change enhances security and manageability of your integrations.
This chapter details the steps for customers and partners throughout the migration, outlining operational changes before, during, and after migration. It also covers important considerations related to integration user management and post-migration validation.
Migration Phases
| Migration Phase | Customers |
Before Migration |
Use SSD authentication. Developer Portal URL: SSD URL All internal integrations use a single ClientId per environment and separate integration users. No action required. |
During Migration |
Developer Portal URL: SSD URL Use the OPERA Cloud Role Manager to reissue passwords to integration users. No new partner integrations can be added. Customers with internal integrations:
After Migration |
New Developer Portal URL: OCIM URL Integration users are no longer required. Customers with internal integrations:
Switching from Resource Owner to Client Credentials Authentication
The image below shows the key differences between the resource owner group (SSD) authentication flow and the new OCIM client credentials flow as well as the steps to update your integration.
Code that calls the OAuth API must be changed (as shown below) to work with OCIM authentication.
urn:opc:hgbu:ws:__myscopes__
Special Considerations During Migration
- Advance Notification: Customers and partners are notified well in advance by Oracle. This includes advice about the enterpriseId to which the chain belongs.
- New Partner Integrations: New partner integrations cannot be initiated with chains that are in the process of migrating. They must wait until the migration has completed.
- Integration User Management:
- Customers: If an integration user’s password must be changed during migration, customers can manage integration users using OPERA Cloud Role Manager. Refer to Managing Interface Users in the OPERA Cloud Identity Management Administrator Guide.
- Partners: Cannot create or change integration users during the migration using SSD. If you need to change a user’s password or create a new user, you must switch to OCIM authentication and reissue the ClientSecret. While a partner may have had more than one integration user in SSD, only one ClientId is permitted per chain for each partner in OCIM.
For Customers
- Access the Developer Portal using the SSD URL.
- If you have internal integrations:
- Each environment (typically one per login) displays a single client ID used by all your internal integrations.
- Authentication uses the resource owner group (SSD) method. This involves sending an integration user’s username and password as well as the client ID and Client Secret as described in Authenticating to Oracle Hospitality Property APIs (SSD).
- No action is required at this stage.
During Migration
Continue to use the SSD URL for Developer Portal access.
- Log in to the Developer Portal.
- Go to the Environments tab.
- Click View Details on your environment.
- Use Reissue Client ID to convert your client to OCIM and receive new OCIM client credentials (ClientId and ClientSecret). Integrations that are using the resource owner group (SSD) authentication will continue to work as before.
- Update all your internal integrations to use the new OCIM client credentials for authentication.
- Customers can add or change integration users and passwords using OPERA Cloud Role Manager. See Managing Interface Users for more information.
- It is not possible for new partners to begin new integrations with chains that are migrating.
After OCIM Migration
- For production OPERA environments: https://<ohip-domain>/<enterpriseID>prd/ui
- For non-production OPERA environments: https://<ohip-domain>/<enterpriseID>uat/ui
Integration users are no longer required or supported. Authentication and access control is now exclusively managed using OCIM client credentials.
ClientIds now appear in OPERA Audit Logs and not in the integration usernames.
- Any integration users previously created for internal integrations are now converted to separate OCIM clients. View these by logging in to the developer portal for a given chain and selecting View Details on the environment card. These are named with globally universal identifiers (GUIDs).
- Alternatively, create new OCIM clients by logging in to the developer portal for a given chain and selecting View Details on the environment card. You can choose part of the name of the OCIM clients you create.
- Update each internal integration to use its own (separate) ClientId instead of a shared ClientId.
- Use the developer portal Analytics tab to check that integrations are not producing errors.
- Confirm all applications and integrations function as expected post-migration.
- Report any issues to Oracle Support – see Opening a Support Request.
- If desired, restrict partner integrations to specific properties by Managing Partner Connections.
- If desired, restrict internal integrations to specific properties by Managing Client Applications.
For Partners
During Migration
- Log in to the Developer Portal. The partner Developer Portal URL does not change.
- Select the environment for the chain being migrated. It will show a 'Migrating Soon' label.
- Use Reissue Client ID to convert the client to an OCIM ClientId. This generates new OCIM client credentials.
- Update your integration(s) to use OCIM client credentials authentication.
- It is still possible to use the resource owner group (SSD) authentication method to obtain OAuth tokens during this period.
- All integrations must be updated to use client credentials (OCIM) authentication prior to completion of the migration.
- It is not possible to access the SSD user interface during the migration.
- If a password change is required during migration, you must do the following:
- Reissue your ClientSecret.
- Change your integration to use OCIM client credentials authentication.
Even if you have multiple integration users per chain, it is only possible to have one ClientId per chain and OPERA environment in the new OCIM authentication model.
Partners cannot initiate integrations with chains that are migrating until migration has completed.
- You will have one OCIM client per chain and OPERA environment, and integration users are no longer required or supported.
- Authentication is exclusively managed through OCIM client credentials.
- Ensure all integrations are updated to use the OCIM client credentials authentication.
- Log in to the Developer Portal, select the Environments tab, and select View Details on environments recently migrated to check whether the customer has limited your access to specific properties. If your access is now restricted to specific properties, verify that restriction with the customer.
- Select the developer portal’s Analytics tab to check that integrations are not producing errors.
- Verify all your applications and integrations are functioning correctly post-migration, and you can obtain OAuth tokens and call APIs.
- Contact Oracle Support promptly if issues are detected. For more information, see Opening a Support Request.
After Migration: Discontinuation of Integration Users
Table 8-1 Troubleshooting Client Credentials Authentication
| API Called | HTTP Response Code | Response Body | Troubleshooting Steps |
OAuth |
403 |
invalid_grant_type_or_scope |
Ensure you include the “scope” attribute in the body with the value “urn:opc:hgbu:ws:__myscopes__”. |
OAuth |
401 |
Enterprise id is required |
Ensure you include the “enterpriseId” header. |
OAuth |
403 |
Enterprise does not have access to gateway |
Ensure you have entered the correct enterpriseId and the correct gateway URL. These can be checked on the developer portal Environments tab. |
OAuth |
401 |
Failed to authenticate application |
Ensure the applicationId is correct and you are using the correct authentication scheme for the environment (which can be seen on the Developer Portal’s Environments tab). Also, ensure the credentials are correct. |
Terms
ClientId
A ClientId is a unique identifier issued by OPERA Cloud Identity Management system (OCIM) for a client application or integration accessing OHIP APIs. In the client credentials model, each integration or application uses its assigned ClientId (along with a secret) to authenticate and obtain access tokens for API calls.
Enterprise Id
In OCIM, each chain is part of an enterprise. Each enterprise has a globally unique identifier called the Enterprise ID. Enterprise IDs are never shared across multiple customers and are a key identifier for routing authentication and authorization requests. It is never the same as any chain code or property code within that enterprise. Refer to Enterprise IDs in the OCIM documentation for the format of Enterprise IDs.
Integration User
An integration user is a user account set up specifically to enable integrations between external systems and OHIP APIs. They are created directly in the Shared Security Domain (SSD). Integration users (along with passwords) are used in the resource owner group (SSD) authentication model. After the migration to OCIM, integration users are no longer needed or supported as authentication is handled through OCIM client credentials.
Authentication Method
An authentication method is the process or protocol used to verify the identity of a client or user for API access. In OHIP, authentication methods include the resource owner group (SSD) flow—where username, password, and ClientId are provided—and the new OCIM client credentials flow — where only ClientId and client secret are required to obtain an OAuth token.
OAuth token
An OAuth token is a secure, time-limited credential issued by the OCIM or SSD authentication systems. After a valid authentication request, the token is provided and must be included in the authorization header (Bearer <token>) of subsequent OHIP API calls to prove identity and access rights.
Customer Internal Integration
A customer internal integration refers to interfaces or applications built and managed by the customer for their own internal business needs. These integrations are distinct from partner or external integrations, and after full OCIM migration, each typically receives its own OCIM client credentials.
Streaming API
The Streaming API permits real-time, continuous delivery of Business Events (such as event or reservation updates) from OHIP to subscribed applications or integrations. See Streaming API (push) for more information.
