Partners Moving to Production
This figure shows the flow of steps for moving to production.
You only need to perform steps 1 to 3 on your first integration.
  1. Join OPN. Please note the minimum level required for OHIP is the base member / Level 0. For more information, visit How Do I Join Modern OPN?
    Note that this level is “zero” and not the uppercase letter O.
  2. Publish your app to the Marketplace. To publish your solution, visit Publish Services and Applications on the Oracle Cloud Marketplace and follow the steps on this page.
  3. Contact us via Slack once your application is listed in the marketplace under the OHIP product category. If you’re not part of the OHIP Slack Community, email us at hospitality-integrations_ww@oracle.com to request your private channel.
  4. Check the customer’s environment by asking customers to verify they are running OPERA Cloud and have an active subscription for OPERA Cloud Foundation. Customers can verify this with their account manager if in doubt.
    If you are using both Early Adopter (v0) and v1 APIS, you will need to subscribe your app to both.
    If your solution involves calling Asynchronous APIs, contact Oracle Support to check if they are supported in the production environment being called. Include the OPERA Cloud URL or gateway URL in the support request.
  5. Create and register an application. Ensure you choose “Production” as the environment.
  6. Add the Customer Environment.
  7. Wait for Customer Approval.
  8. Obtain credentials.
  9. View environment.
  10. Call the APIs.
