Quick Start for Hoteliers (in UAT Environment)
Prerequisites
The hotel must purchase an OPERA Cloud Foundation SKU.
OHIP is not available for hotels using a legacy OPERA Cloud SKU.
The chain containing properties that are on OPERA Cloud Foundation must be onboarded with OHIP.
The onboarded chain and properties must be on Oracle Cloud Infrastructure (OCI) and NOT in a legacy data center.
Making API Calls
Assign the DEVELOPERPORTALACCESS role to all OPERA Cloud users requiring access to the OHIP Developer Portal. This will support Single-Sign On (SSO) with OPERA Cloud. See Getting Started for more information.
- UAT: Refer to your Welcome email for this URL.
- PROD : Refer to your Welcome email for this URL.
Access the Developer Portal for UAT or PROD (using the URLs from your Welcome email) and click the Environment tab.
Click the environment card and to copy the enterpriseID, scope, client Id, and secret. See Using the Oracle Hospitality APIs for more information.
Register a new application in the Applications tab of the OHIP Developer Portal. When creating a new application, subscribe the application to all the APIs that appear. See Register and Manage Applications for more information.
Enter the hotel ID from which you want to get data. This is not the same ID as the chain admin and should be the ID of a specific hotel.
If you need to call early adopter (v0) Oracle Hospitality Distribution APIs, send an email to hospitality- integrations_ww@oracle.com requesting to join the early adopter programme. You must reply to the email accepting the terms and conditions of the programme before access is provided.
Configuring Postman
Obtain the postman collections via the following:
Cloning our github repo and then importing the collections / environment under the postman-collections folder.
Forking our public postman workspace directly.
Set up a postman environment (one for UAT and one for PROD) with the previously obtained information plus the gateway URL:
HostName: API gateway URLs for UAT and PROD. Refer to your Welcome email for these URLs.
CLIENT_ID: Client ID previously obtained from the Developer Portal for UAT or PROD.
CLIENT_SECRET: Client ID previously obtained from the Developer Portal for UAT or PRO.
AppKey: The application key previously obtained .
EnterpriseID: The unique identifier for the enterprise.
Scope: The scope variable representing the permissions of the client for authorization.
HotelId: Hotel ID against which you want to perform actions. For example, obtaining reservation data.
Once all environments have been configured, select the Get OAuth Token collection and make a call.
If everything is set up correctly, OHIP responds with a HTTP 200 OK response, which includes the OAuth token.
Now you can try out other collections as required.
