7 Limitations and Constraints
  • If your integration is with a property using OPI, you cannot send the clear credit card number as a payment method with the Property APIs. Oracle does not provide an automatic token exchange service. If credit card numbers are received, OPERA Cloud removes/ignores them.
  • If the guest is providing you with a credit card number, you must exchange it for a token from the same PSP in use at the property. For additional information, review the Implementation Guide for Reservations Credit Card Payment Methods, specifically Step 4.
  • The Property API responses do not provide the full credit card number.
