Configuring Property Interface Postings
Editing Interface Postings
From the Administration menu, select Interfaces, then select Property Interfaces.
Enter search criteria and click Search.
Select the interface, then click the vertical ellipsis and select Edit.
Select the Postings link and click Edit.
Reference Field. Select the value you would like to see entered in the Reference field for postings. This field allows you to provide additional information about the charge. When the IFC>Swap Reference and Supplement application parameter is set to Y and a value exists in the Reference field, any interface posting's will have the information selected in this field displayed under the Supplement column. Depending on the how the default folio is setup it will either display supplement or reference field information on it. Switching this parameter will make the posted charge have different data in the different fields and will display differently on the billing screen as well as the folio.
If attributes are selected for the Reference or Supplement fields, those will take precedence over the attribute selected for this field. But if both of Reference or Supplement fields are blank, then this attribute selected will be used.-
Do not post: Does not record and zero charge postings.
Post: Posts zero charge postings.
Only to IFC_HIST: Only sends zero charge postings to the history file.
Post and to IFC_HIST: Records zero charge posting and records them to the history file.
Post to IFC_HIST: Select this check box to have the interface record a copy of all postings to the IFC_HIST table.
Zero Charge Postings.: Set this option to configure how the interface will deal with zero charge postings.
Postings. Set this option to configure the different checks the interface should make before allowing a posting. Your selection options are:
Do not check NOPOST flag : When selected, sends 990000000000 as the credit limit to the interface.
Check NOPOST flag only: When selected, sends 990000000000 as the credit limit to the interface when the No Post flag is not selected on the reservation. If the No Post flag is selected on the reservation, then the credit limit will be 0.
Check credit limit: The following displays how the credit limit will be calculated when this is selected for Postings: Actual Credit Limit(greatest of the approval amount or the credit limit set for the guest payment method) - Guest folio balance - Charges due for remaining stay.
Check credit limit per Guest: Controls on an interface-by-interface basis which interfaces should check the individual spending limit. When selected, the interface will check to see if there is available spending for that particular guest's key, and will then further check that there is enough credit on the room.
Number Masking: This setting allows you to indicate whether or not to mask any details displayed in the supplement field. Select a value from the list.
Default Charge: This default charge will be used when the incoming minibar posting has none or invalid OPERA Cloud articles in the PostSimple message.
Override Credit Limit: This check box controls whether to allow an override of the credit limit on postings. When this check box is selected, a PostRequest that is over the credit limit will fail with No Credit response unless the payment method included in the PostRequest is configured to a Room posting type that is associated with the Manager Override (see Configuring Property Interface Transaction Codes for details).
Check "NoPost" during guest information change: Select this checkbox to check the NoPost field on the reservation when updating the guest information.
IFC Generates Tax.: The functionality for this check box is also based on how the IFC Post Exclusive Tax As Itemizer OPERA Control is set. Selecting the check box will have the IFC include the tax and leaving the check box un-selected will have PMS generate the tax. But when the IFC Post Exclusive Tax As Itemizer OPERA Control is active and this check box is selected, then exclusive taxes will be posted as itemizers by the POS Interface.
Charge Scaling: This option allows you to set the various charge scaling options. Use this to divide or multiply a charge.
Post Type: Select the posting type. The available options are:
Direct: Uses the actual dollar amount from the message.
Minibar: Uses the dollar amount from the Article Configuration, not from the message.
Phone: Uses the dollar amount, based on the transaction configuration, from the Trans Codes IFC Configuration Tab, not from the message.
Reference: Click to select the attributes to include in the Reference field for postings. Select values from the Available panel and click > to move to the Selected panel. When attributes are selected here, they will take precedence over the item selected in the Reference Field drop down list field.
Supplement: Click to select the attributes to include in the Supplement field for postings. Select values from the Available panel and click > to move to the Selected panel. When attributes are selected here, they will take precedence over the item selected in the Reference Field drop down list field.
Click Save.
Parent topic: Configuring Property Interface
