Copying Conversion Codes
Copying is an efficient way to populate the interface conversion codes, instead of manually inserting the codes one by one. Copy Conversion Codes helps you to copy the conversion codes from OPERA Cloud to the selected interface. Copy option also validates new and active/inactive OPERA Cloud codes. It copies these codes to the Interface Mapping conversions along with their respective groups. An example of an extensive list of conversion codes can be the Countries or Rate Codes. This form copies the conversion codes from OPERA Cloud based on the activated conversion codes for this interface. When copying, OPERA Cloud and external system values are populated with the same value in the conversion details.
To select conversion codes:
  1. From the OPERA Cloud Exchange menu, select Interface Setup and then select Copy Conversion Codes from the drop down list.
  2. On the Copy Conversion Codes screen, Property is selected by default. Select an Interface and click Search.
  3. In the search results table, select a Conversion code row that is to be copied and then click Copy. You can select multiple rows.
  4. You get an Information pop-up validating that it is copied successfully. Click OK.
