25 Interface Setup
Interface setup search allows you to search by Property or
by External systems code. The recommendation is to search interfaces
by Property to get all configured interfaces, or search by interfaces
to get a specified interface. Selecting multiple properties and interfaces
provides search results for all selected interfaces in the search
results.
               Searching an Interface
- From the OPERA Cloud Exchange menu, select Interface Setup and then select Interface Setup from the drop down menu.
- From the Search panel, select Property and click Search.
- In the search results table, click the vertical ellipsis Actions menu to Edit or Delete the setup. Search results table shows the External System Property Code and External System Active/Inactive status.
- Click I Want To . . .to update exchange capabilities. It allows you to configure the Business Events. It also allows you to activate External System if the external system is in an inactive state.
