Configuring Hubs
Hubs are used in combination with Chain and Property roles to control user access to properties, functionality and data.
A default DFLT_[TENANT] hub is created automatically upon provisioning and all properties provisioned for your tenancy are associated to this hub.
You can configure additional hubs and associate a subset of properties with one or more hubs; enabling you to cluster properties according to your business need.
Once configured you then assign hubs to users in order to grant them access to properties. If a user is not assigned a hub, the user will not be able to log in. See Managing Users.
You are only able to manage hubs that are assigned to you. Hubs created by other users and not assigned to you will not be listed in search results.Adding a Hub
From Administration menu, select Enterprise, select Chain and Property Management, and then select Hubs.
Click New and enter the following details::
Hub. Enter a Hub.
Name. Enter the full descriptive name for the Hub/CRO.
Address. Enter the street address.
City. Enter the city location for the Hub/CRO from the list.
Postal Code. Enter the zip or postal code number.
Country. Select the country location for the Hub/CRO from the list.
State. Select the state location for the Hub/CRO from the state list of values.
Telephone. Enter an international phone number for the Hub/CRO.
Toll Free. Enter a toll–free 1-800 number for the Hub/CRO.
Email. Enter the email address to associate with the Hub.
Currency. Select the currency for the Hub/CRO. This is used as the default for all currency calculations unless specified elsewhere.
Currency Format. Select the currency format for the Hub.
Short Date Format. Select a format type for the short date.
Long Date Format. Select a format type for the long date (for example, ddth Month YYYY or Month ddth YYYY).
Time Format. Select the time format from the list of values. This is the format for the time stamp used by the property
Time Zone. Select the time zone where the Hub/CRO is located.
Base Language. Select a base language for the Hub.
Click Save.
Assigning Properties to a Hub
Enter a Hub and click Search.
Select the Hub, then click the vertical ellipsis and select Edit.
Click the Manage link located under the Associated Properties section.
Under Available Properties, select the property you want to associate with the hub and click the down arrow to move the selected property to the Associated Properties grid.
Click Save.
Editing a Hub
Select the Hub, then click the vertical ellipsis Actions menu and select Edit.
Update the configuration.
Click Save.
Deleting a Hub
Select the Hub, then click the vertical ellipsis Actions menu and select Delete.
Click Delete to confirm.
Parent topic: Chain and Property Management
