Configuring Auto Folio Settlement Types
Adding Auto Folio Settlement Types
From the Administration menu, select Financial, select Cashiering Management, and then select Auto Folio Settlement Types.
Click New and enter the following details:
Code: Enter a Code to represent the auto folio settlement type.
Description: Enter a Description of the auto folio settlement type.
Manage Translation: Click to add translated descriptions per language
Sequence: Enter a Sequence to determine the order in which the type appears in the Auto Folio Settlement Types list.
Click Save.
Editing Auto Folio Settlement Types
Enter search criteria and click Search.
Select a settlement type and click the vertical ellipsis Actions menu, click Edit.
Update details.
Click Save.
Deleting Auto Folio Settlement Types
Select a settlement type and click the vertical ellipsis Actions menu, click Delete.
Click Delete to confirm.
Parent topic: Configuring Cashiering Components
