Custom Headers
Custom Headers configuration is provided for defining the
additional custom header names and values for the Outbound Codes created.
Custom Headers allow you to define a maximum of five custom header names and values that can be communicated with external systems during API calls.
Custom Headers configuration is available under the I Want To . . . options.
- Search for the Outbound Code created at the Global (Chain) or Property Level.
- Click the I Want To . . . icon from the search results row where you want to define Custom Headers.
- The Custom Headers screen launches in a pop-up window.
- Click Edit to define the Header Name and Header Value and then click Save.
- You can Edit and modify values for any changes or you can set the blank field to Delete and then click Save to update the configuration.
Parent topic: Configuring Outbound Systems
