Advanced Dynamic Base Rates
Overview
The Advanced Dynamic Base Rate enables you to create a rate derived from another rate (a Base Rate) or derived from both a Base Rate and a BAR Based rate. This rate structure provides flexibility by enabling you to configure the rate as either a flat amount or a percentage. In addition, you can choose to apply the BAR rate amount to the Advanced Dynamic Rate calculation and you can optionally select a rounding method. Advanced Dynamic Base Rate also offers the ability to compare the rate configuration details with other Base Rate amounts.
Example 13-3 Example 1
ADBR (Advanced Dynamic Base rate) = to be determined
BASE1 (BASE rate) = $100.00
BAR1 (BAR rate) = $80.00
Table 13-12 Rate Code Setup
Base Amount | BAR Base Amount | Apply BAR | Compare with Rate Details |
$10.00 (Flat) |
10% |
Yes |
No |
Table 13-13 Look To Book Rate Availability Result
Rate Code | Nights | Adults | Amount |
ADBR |
1 |
1 |
$88.00 |
Table 13-14 Rate Code Setup
$10.00 (Flat) |
10% |
Yes |
Yes |
Table 13-15 Look To Book Rate Availability Result
ADBR |
1 |
1 |
$88.00 |
Example 13-4 Example 2
BASE1 (BASE rate) = $50.00
Table 13-16 Rate Code Setup
$10.00 (Flat) |
10% |
Yes |
Yes |
Table 13-17 Look To Book Rate Availability Result
ADBR |
1 |
1 |
$60.00 |
Table 13-18 Rate Code Setup
$10.00 (Flat) |
10% |
Yes |
No |
Table 13-19 Look To Book Rate Availability Result
ADBR |
1 |
1 |
$88.00 |
Parent topic: About Rate Codes
