Interface Resync - Rates
You have to select either a date range or check the rate codes in order to resync rates. A ‘Total Count’ of all active Rate Codes during the time frame entered will be displayed. User has the option to choose each rate code or all if necessary for resync to an external system.
  1. From the OPERA Cloud Exchange menu, select Interface Resync, and then select Rates, from the drop down list.
  2. The Type and Property values are taken by default. Search and select an Interface that is to be resynced.
  3. In the Rates to Resynchronize panel, enter the From Start Date. You must select the first rate code start date for the resync. Only rate codes valid for this date are to be shown.
  4. Enter To Start Date. You must select the last rate code start date for the resync. Only rate codes valid for this date are to be shown.
  5. Search and select Rates. Shows how many active rate codes you have in the OPERA Cloud database. Once you have selected a date range the count is adjusted to match the number of rate codes that fall into your selected date range.
  6. Click Resync or Resync History.
