Changing Revenue Type
The Change Revenue Types Utility can be used to update an event revenue type to another event revenue type. For example, if you create a new revenue type, BEV this utility will convert the existing WINE revenue type (which may be associated with events, menus, menu items, resource items, revenue type cross references, etc.), to the BEV revenue type.
The Change Revenue Types Utility can be run while users are accessing OPERA Cloud. However, if you are actively working on a record that would be impacted by the change utility, a message warns that a lock has occurred, which prevents the utility from continuing.
  1. From the Toolbox menu, select Utilities, select Data Management then select Change Revenue Type.
    1. Property: Select or confirm the property.
    2. From Revenue Type: Select a revenue type from the list; inactive revenue types are included in this list.
    3. To Revenue Type: Select a revenue type from the list.
  2. Click Review to review the implied changes.
  3. Click Change Revenue Type .
