Configuring Chain Roles
Adding a Chain Role
Roles created in Oracle Identity Manager (OIM) appear with a red triangle and exclamation mark to indicate the role does not exist in OPERA Cloud.
From OPERA Cloud Role Manager, select Manage Chain Roles.
Enter search criteria, then click Search.
Select the role created in OIM (red triangle), then click the vertical ellipsis Actions menu and select Create Role from LDAP.
The Manage Role page appears from which you can grant various tasks to the Chain Role. For more information, see Assigning Tasks to a Role.
From the top panel of the Manage Role screen, complete the following fields:
Role:This field is read-only and displays the name of the role as it was configured in OIM.
Display Name: Enter the display name for the role in OPERA Cloud.
Description: Enter a description of the role in OPERA Cloud.
Click Save.
Editing a Chain Role
Select the role, then click the vertical ellipsis Actions menu and select Edit.
Under Available Tasks, select or deselect the assigned tasks from the role.
For more information, see Assigning Tasks to a Role for more information.
Click Save.
Viewing Users Assigned to a Chain Role
Select the role, then click the vertical ellipsis Actions menu and select View Users.
The Users screen appears with the User ID and Display Name for each user.
Deleting a Chain Role
Select the role, then click the vertical ellipsis Actions menu and select Delete Role from Database.
Click Yes to confirm the deletion.
Parent topic: About Roles
