Configuring Block Conversions
Adding Block Conversion
                        Select the Administration menu, select Booking, select Block Management, and then select Conversions.
                        Click New and complete the following fields:-
                                 Code: Enter a code (up to 10 characters) for the conversion rating.
                                 Description: Enter a text description of the conversion rating.
                                 Sequence: Enter a number that controls the position of this code in listings. Codes without a sequence number assigned are listed in alphabetical order following codes with a sequence assigned.
                        Click Save.
Editing Block Conversion
                        Enter search criteria and click Search.
                        In the search results, select the code and click the vertical ellipsis Actions menu and select Edit. -
                              Update the configuration
                              Inactive: Select to mark this code inactive. Inactive codes are not available for selection from lists. The code remains for historical and statistical purposes only.
                        Click Save.
Deleting a Block Conversion
- In the search results, select the code and click the vertical ellipsis Actions menu and select Delete.
                        Click Delete to confirm.
Parent topic: Block Management Overview
