Processing Credit Card Vault Conversion
When the CC Vault Function check box is selected for the CCW and/or EFT interface, use this utility to convert credit card PAN to unique ID numbers that are used instead of the credit card PAN to process transactions.
From the Toolbox menu, select Utilities, select Data Management, and then select Credit Card Vault Conversion.
Property: Enter or select the property.
Click Start Tokenization.
Parent topic: Data Management
