Using Preference Utility
Use the Preferences Utility to delete preference types from configuration, profiles, and all reservations; the preferences may be global or property specific.
Tip:
Use + to expand the preference groups. You can also search for preferences using the filter.Deleting Preferences
From the Toolbox menu, select Utilities, select Data Management then select Preference Utility.
Select the Delete Preferences tab.
Global: Select to delete global preference.
Property: Select to delete property preferences.
Property: Select a property from the list.
Select one or more preferences from the Available Values panel, then click Add to move to the Selected Values panel.
Click Delete Preferences.
Converting Preferences
Use to convert property preferences to global preferences
Select the Convert to Global tab.
Click Convert Preferences.
Parent topic: Data Management
