Managing Room Maintenance Requests
Room Maintenance enables you manage and resolve maintenance requests such as changing a light bulb , repairing a faulty lock, service a faulty air conditioning unit and so on, for guest rooms.
You can assign maintenance requests to staff according to a staff member’s skills and/or qualifications.
You can add images to the requests. An icon is displayed in the search results for maintenance requests with image(s) available.
The management of maintenance tasks is also available on the OPERA Cloud Mobile web app.
Adding Maintenance Requests
From the OPERA Cloud menu, select Inventory, select Rooms Management, and then select Room Maintenance.
- Click New and enter the following
details:
Room: Enter or select room(s) from the list.
Reason: Select a reason (type) from the list.
Remarks: Enter descriptive information regarding the maintenance request.
Click Add Image to upload images.
Click an image to zoom and use the navigation arrows to scroll.
To delete an image, click the X button.
User: Select a user to assign the task to a specific user.
Expected By.: Enter or select a completion date.
Click Save.
Editing Maintenance Requests
Enter search criteria and click Search.
Select a maintenance request from the list and click Edit.
Update details.
To assign a request select a User. -
Click Save.
Deleting Maintenance Requests
Select a maintenance request from the list and click Delete.
Click Delete to confirm.
Resolving Maintenance Requests
Resolved maintenance requests are purged 90 days after resolution date.-
Select a maintenance request from the list and click Resolved check box (column).
Generating Maintenance Report
Click Vertical Ellipsis, select Report.
Update report parameters.
Select report destination.
Click Process.
