Activating Prepaid Card Functionality
The OPERA Cloud users with the PPCONF role can access OPERA Cloud and activate the prepaid card parameter for a new property. Once the parameter is active, all prepaid card transactions are supported by OPI Cloud Service via service-to-service communication.
Log in to OPERA Cloud using the URL provided.
Enter your User Name and Password in the fields provided.
From the Administration menu, select Enterprise, then select OPERA Controls.
OPERA Control groups are listed down the left side panel, select the Cashiering group.
On the right-side panel, turn ON the Prepaid Cards parameter to activate all prepaid card transactions for the property through OPI Cloud.
The Prepaid Card Purchase Transaction Code parameter is visible only when a Stored Value System (SVS) interface is active.
Once the parameter is active, you can configure the property for prepaid card integration.
