4 Card Mappings
The OPERA Cloud users with the CCCONF or PPCONF role can view or
update the existing card mappings based on the requirements. You can
sort the details in ascending or descending order using the sorting
icon.
You can view the Card Mappings tab only once the Core Configuration details are updated.
