Credit Card Manual Entry
Using the OPERA Cloud Application.
Or
You can manually enter the details using the payment device.
For both methods, you need to notify your Payment Partner to make sure that they are informed of the requirement to support these transaction types.
In order to test the below scenarios, refer to the Booking a Reservation section of the OPERA Cloud user guide.
- See Credit Card Guarantee through the OPERA Cloud Application (Manual Entry – OPERA Pay for Tokenized Properties) for details.
- See Credit Card Guarantee through the OPERA Cloud Application (Manual Entry Into Payment Device for Tokenized Properties) for details.
- See Credit Card Guarantee through the OPERA Cloud Application (Card Present for Tokenized Properties) for details.
- See To View Token ID (Tokenized Properties) for details.
Non‑Tokenized Properties are OPERA Cloud properties that process credit‑card payments without using tokenization. They are not connected or integrated with a Payment Service Provider through OPI Cloud. As the OPI Cloud Token Proxy Service is not activated, payment‑card numbers (PANs) are not converted into tokens. Instead, credit‑card data is stored directly (typically masked) in OPERA Cloud’s card fields.
