Required Software
The following table lists the Oracle software that is required in order to execute Oracle Health Insurance:
Oracle Product | Version as of 3.20.1.0.x | Version as of 3.20.3.0.x |
Oracle Database Enterprise Edition |
Either 12c Release 2 (12.2.0.1) or 19c (latest patch release) |
19c (latest patch release) Apply the patch for "Bug 30806757 - ORA-8103 when inserting into a new partition with is json constraint in place (Doc ID 30806757.8)". |
Partitioning (Oracle Database Enterprise Edition Option) |
Oracle WebLogic Suite for Oracle Applications (may be used only as an embedded runtime for eligible Oracle Applications) Options required with WebLogic: Oracle Coherence; Oracle TopLink; Oracle Application Development Framework (ADF) |
12.2.1.3 |
12.2.1.4 (latest patch release) Minimal required patches, to be applied in the order mentioned:
For the Oracle Database and Oracle WebLogic server make sure to always apply the latest Critical Patch Updates. |
The Oracle Database and Oracle WebLogic server as well the ADF runtime libraries need to be installed. Make sure to use the "Fusion Middleware Infrastructure Installer".
For certified operating systems for the Oracle Database and Oracle WebLogic server check Certifications on My Oracle Support for these Oracle products. OHI applications are developed and tested on Oracle Linux.
Make sure to check Certifications on My Oracle Support for certification of OHI applications with the following:
Certified Java runtime versions
Certified browsers
The Oracle Real Application Clusters (RAC) database option can be used with OHI applications in order to achieve a high-availability setup. RAC should not be used for scalability in combination with OHI applications.
