Required Software
The following table lists the Oracle software that is required to run Oracle Health Insurance:
Table 1. Required Software
Oracle Product Versions
Oracle Database Enterprise Edition
19c (latest patch release)
Partitioning (Oracle Database Enterprise Edition Option)
Oracle WebLogic Suite for Oracle Applications (may be used only as an embedded runtime for eligible Oracle Applications) Oracle software required to run Oracle Health Insurance. Options required with WebLogic: Oracle Coherence
15.1.1.0.0 (latest patch release) e Oracle software required to run Oracle Health Insurance. Minimal required patches, to be applied in the order mentioned:
  • 37732915 WLS PATCH SET UPDATE 15.1.1.0.60107
  • 37658354 Coherence 15.1.1.0 Cumulative Patch 1 (15.1.1.0.1)
For Oracle Database and Oracle WebLogic Server, always apply the latest Critical Patch Updates.
Oracle Database and Oracle WebLogic Server must be installed. Make sure to use the Generic Installer.
For certified operating systems for the Oracle Database and Oracle WebLogic server, check certifications on My Oracle Support for these Oracle products. Oracle Health Insurance applications are developed and tested on Oracle Linux.
Make sure to check certifications on My Oracle Support for certification of Oracle Health Insurance applications with the following:
  • Certified Java runtime versions
  • Certified browsers
The Oracle Real Application Clusters (RAC) database option can be used with Oracle Health Insurance applications to achieve a high-availability setup. RAC should not be used for scalability in combination with Oracle Health Insurance applications.
