Reinsurance
Reinsurance Setting
An enrollment product type can have one or more reinsurance settings. A reinsurance setting specifies the percentage that should be paid out to a reinsurer.
Table 1. Reinsurance Setting
Field Description
Enrollment Product Type
The enrollment product type for which the reinsurance setting is applied
Organization
The organization that acts as a reinsurer
Percentage
The percentage of the premium that has to be payed to the reinsurer
Alias Code
The alias code for reinsurance (this is transferred to OHI Claims in the enrollment response if reinsurance is applied)
Start Date
The start date of the reinsurance setting
End Date
The end date of the reinsurance setting
Constraints:
  • It is not allowed to have an overlap in time validity for reinsurance settings with the same enrollment product type, organization and alias code
Reinsurance Exclusion
A reinsurance setting can have one or more reinsurance exclusions. A reinsurance exclusion specifies the premium types, adjustments and surcharges that are excluded from the base amount used for the reinsurance payment calculation.
Table 2. Reinsurance Exclusion
Field Description
Reinsurance Setting
The reinsurance setting for which the exclusions apply
Premium Schedule Type
The excluded premium schedule type
Schedule Definition
The excluded schedule definition
Note that not all schedule definitions are relevant to reinsurance. For example, schedule definitions that belong to the Fee schedule definition type have no relevance within the context of a reinsurance exclusion.
Reinsurance Treaties
The following entities are used to store the reinsurance treaty related details:
Reinsurance Treaty Types
Table 3. Reinsurance Treaty Types
Field Description
Code
The code of the reinsurance treaty type.
Description
Treaty type description.
Display name
Display name for the reinsurance treaty.
Table 4. Reinsurance Treaties
Field Description
Code
The code for the reinsurance treaty.
Description
Description of the treaty.
Type
The type of the treaty, reference to reinsurance treaty type.
Retention percentage
The percentage of the premium retained by the payer or costs per claim for the payer.
Retention amount
The maximum amount for which the payer is liable, typically per member or policy.
Excess of loss amount
The maximum amount for which the payer is liable, typically per group of policies or catastrophic event.
Commission percentage
Commission percentage which the payer collects from the reinsurer.
Priority
Priority in which the treaty is to be applied.
Enabled?
Reinsurance Treaty enabled?.
Start Date
Start date for the reinsurance treaty.
End Date
End date for the reinsurance treaty.
Reinsurance Treaty Reinsurer
Table 5. Reinsurance Treaty Reinsurer
Field Description
Reinsurer
The organization that acts as a reinsurer.
Percentage
Reinsurer’s percentage split.
Treaty
Reference to the reinsurance treaty.
Reinsurance Treaty Premium Scope
Table 6. Reinsurance Treaty Premium Scope
Field Description
Schedule Definition
The included schedule definition.
The included premium schedule type.
Treaty
Reinsurance Treaty Benefit Scope
Table 7. Reinsurance Treaty Benefit Scope
Field Description
Service Option Service Code
Service codes that are included in the treaty.
Treaty
Reinsurance Treaty Enrollment Scope
Table 8. Reinsurance Treaty Enrollment Scope
Field Description
Enrollment Product
The enrollment product to which the treaty applies.
Group Account Product
The group account enrollment product to which the treaty applies.
Group Client
The group client to which the treaty applies.
Treaty
