Load Smart Event Encoding model
About Smart Event Encoding
The Smart Event Encoding feature enables automatic event coding when verbatim or event descriptions deviate from an exact Preferred Term (PT) or Lowest Level Term (LLT) match. This feature works only when the Smart Event Encoding Model is available in the system. You can upload the Smart Event Encoding Model through the Dictionary Management menu.
Tip:
Oracle recommends you to update the Smart Event Encoding Model as soon as a new model becomes available following each MedDRA dictionary release. Although the feature supports using an existing model with a newer MedDRA dictionary version, it works best when the MedDRA dictionary and Smart Event Encoding Model versions match.For the available released versions, see the article KB317773 on My Oracle Support.
Prerequisites
- Set the Maintenance Mode to System down for Maintenance. For more information, see Configuring System Maintenance.
- To get the latest Smart Event Encoding Model (.zip file):
- Argus Safety (on-premise) users—Download the latest Smart Event Encoding Model (.zip file) from My Oracle Support (Patch ID 36147492).
This .zip file is password-protected. Log a Service Request (SR) to obtain the password. - Safety One Argus (Cloud) users—Create a change request (CR) in Life Sciences Customer Support Portal, asking for Smart Event Encoding model (.zip file) and also specify the MedDRA version and the environment in the request.
- The Smart Event Encoding Model will be optimized to the latest MedDRA version.
- Make sure that the Smart Event Encoding Model being uploaded is not already loaded in the system to avoid errors.
To load the Smart Event Encoding Model:
Parent topic: MedDRA dictionaries
