Validation Check of Incoming Message
Before updating the transmission status of the reports, the application identifies the type of incoming message and validates it. The ICSR service processes all the incoming messages located in a folder in either the incoming EDI directory or the physical media directory. Incoming ICSR Messages are retrieved as SGML from a shared directory. The incoming folder is configurable through the Oracle Argus Interchange Mapping Utility. The ICSR message is parsed to check the validity of the SGML file using the correct version of DTD. The incoming message is saved after checking that the message is in compliance with the DTD.
The recipient of the ICSR message acknowledges receipt of the message and notifies the sender about the validity and usability of the data in the reports. (The acknowledgment message is called an ICSR Acknowledgment Message.) When a message is acknowledged, the workflow status of the ICSR report is updated with one of the following three statuses:
  • All reports loaded into recipient database
  • ICSR Error, not all reports loaded into database
  • SGML parsing error no data extracted
The acknowledgement contains two sections, one concerning the validity of the message as a whole and the second containing comments on the validity of the individual reports within the message. Create a folder and configure it through the Oracle Argus Interchange Mapping Utility, where all the incoming messages can be stored. The Interchange service processes the received message and moves it to the Archive folder.
The message is validated based on the ICH ICSR acknowledgement specifications and the format of the message identified by the DTD version. The correctness of the receiver and sender identifiers present in the message header is also validated to verify that the message is not sent to the wrong recipient.
The content of the message is validated based on the following:
  • Required Data
  • Data Type
  • Data Length
  • Field Value
The system identifies the message type (acknowledgement) and the DTD version of the message. In Oracle Argus Safety, if the application is unable to identify the message type or DTD version, the error is logged in the log table and no further processing occurs. In Oracle Safety One Argus, the failed report is marked as invalid and appears in the Intake Monitor with the applicable error message. In both environments, the application then sends an email to the configured email address indicating that the message could not be read.
The application checks for the presence of the duplicate in the system based on the ‘Sender identifier' and ‘Acknowledgement Message Tracking #'. Processing of the acknowledgement is stopped if a duplicate message is found in the database, and an error message is created.
The following table describes the error messages and shows the possible reasons for the errors.
Process Error message Possible Reason for error
Read the Incoming message from the folder
XML File not in path.
File is removed.
Identification of the incoming message type
<<File Name>> not a valid XML File
File format is not as per ICH guidelines.
Not valid ICH ICSR message Tag ‘<ichicsrmessageheader>' not found
File does not contain the valid ICH Message Header.
Failure to identify the type of incoming message. Either Tag <messagetype> is missing/misspelled or tag does not contain valid value. The valid values are ICHICSR, ICHICSRACK
The incoming file is identified as a message or acknowledgment. The identification value is wrong.
Record not found in CFG_PROFILE table for DTD version '2.0', DTD release '1.0', Active profile = 'Y' and profile type starts 'ACK%'
Profile does not exist in cfg_profile table.
Validation of the incoming message type
M2 Validation failed for incoming message. The following are the elements and values:<<Element, value>>
M2 validation failed on the message header.
Identification of the incoming acknowledgement type
Invalid ICH ICSR message Tag ‘<messageacknowledgment>' not found.
File does not contain the valid ICH Acknowledgment Header.
Processing acknowledgment
Record not found in MESSAGES table for the ICSRMESSAGE number <<MessageNum>> ICSRMESSAGE receiver identifier <<receiver info>> for the received acknowledgment
Record is deleted from the database.
Duplicate acknowledgment received for ICSRMESSAGE number <<message number>> and ICSRMESSAGE RECEIVER IDENTIFIER <<receiver info>>
Acknowledgment already exists for this message number.
<reportacknowledgment> section is missing from the received acknowledgment, MESSAGE number <<message number>>
Acknowledgment does not contain the report acknowledgment body.
Record not found in SAFETYREPORT table for company number <<Company Number>> and msg_id <<message id>>
Record is deleted from SAFETYREPORT table from database.
The following are examples of the email messages that are sent to the configured email address if message validation fails:
  • In the case of invalid XML formatting:
    Subject: <<file name>> not valid XML formats file
    Content: This mail has been sent by the system to notify that the system has failed to identify the file <<file name>> as a valid XML file.
    Error has occurred on Line: <<line no>>, Source Text <<Error Text>>, Error Code <<Parsing Error Code>>, Error Reason <<Error Reason>>
    Thanks,
    << ICSR service user >>
  • If the application fails to identify the incoming message:
    Subject: Failure to Identify the Type of Incoming Message.
    Content: This mail has been sent by the system to notify that the system has failed to identify the type of the incoming message (Acknowledgement or a Message) present in the file <<Incoming Message File Name>>.
    Thanks,
  • For validation failure of the incoming acknowledgement:
    Subject: Validation Failure of the Incoming Acknowledgement.
    Content: This mail has been sent by the system to notify that the system has failed to further process the incoming acknowledgement present in the file <<Incoming Message File Name>>.
    The following are the reasons for this failure:
    #<n>. <<Insert the corresponding relevant error message.>>
    Thanks,
You can view acknowledgement details for a report in the Report Details Dialog. Information includes the acknowledgement message tracking number, the acknowledgement report tracking number, the date the acknowledgement was initiated, the company ICSR message, and the error reported by the receiver.
The status of the each ICSR report is updated based on the information extracted from the ICSR acknowledgment irrespective of the transmission status (Success or Failure). Refer to View Acknowledgement Information for the steps to follow to see detailed acknowledgement information for a report.
