Load Smart Event Encoding model
The Smart Event Encoding feature enables automatic event coding when verbatim or event descriptions deviate from an exact Preferred Term (PT) or Lowest Level Term (LLT) match. This feature works only when the Smart Event Encoding Model is available in the system. You can upload the Smart Event Encoding Model through the self-service dictionary tool.
Tip:
Oracle recommends you to update the Smart Event Encoding Model post each MedDRA dictionary release. This feature works best, when you use same version of MedDRA dictionary and Smart Event Encoding Model.Prerequisites
- Set the Maintenance Mode to System down for Maintenance. For more information, see Configuring System Maintenance.
 - Download the latest Smart Event Encoding Model (.zip
                                        file) from My Oracle
                                                Support (Doc ID 36147492).
This Doc ID is password-protected. Log a Service Request (SR) to obtain the password.
- The Smart Event Encoding Model will be optimized to the latest MedDRA version.
 - Make sure that the Smart Event Encoding Model being uploaded is not already loaded in the system to avoid errors.
To load the Smart Event Encoding Model:
