Use other (than English) language text
Certain fields on the Case Form let you enter text in languages other than English. The non-English text that is entered in these fields can also appear on Expedited reports.
When a case is in a specific workflow state, for which the parameter Enable multi-lingual fields in locked case is set in the workflow configuration, then the Multilingual dialog boxes are enabled for data entry, even when the case is locked globally or locally.To enter text in a language other than English:
- Click the English language icon.
- Use the pane associated with English to enter the English language text. Select the required language from the Select Language drop-down list to enter text in that language.
- After completing text entry, you can perform a spell-check for the text.
The table below displays icons representing different languages.
| Icon | Language |
English |
Japanese |
Language other than English or Japanese |
For more information, see:
Parent topic: Know your basics
