System requirements: Application servers
Feature Application server requirement
Operating system
  • Microsoft Windows Server 2019 Standard
You can install on an English (United States) operating system only.
Processor
Minimum: 2.0 GHz or higher
Recommended: Multiple processors, each 2.0 GHz or higher
Memory
Minimum: 8 GB
Recommended:16 GB
Disk space
In addition to the space required for the operating system:
  • Approximately 500 MB for the Oracle Central Designer software
Connectivity
100/1000 NIC
Display
  • 1024 x 768 or greater resolution
  • 256 or more colors
Software
Windows components:
  • Internet Information Services (IIS) 10.0
  • ASP.NET 4.7 or higher
  • Microsoft .NET Framework 4.8
  • SMTP server, which sends email notifications during deployment. For this feature to work as expected, you must install and configure the SMTP server.
Oracle client components:
  • Oracle Database Client 19.19
  • Oracle Services for Microsoft Transaction Server (MTS) for your Oracle Client version
  • Oracle Data Provider (ODP) for .NET version 4.8.03761
Services
The Distributed Transaction Coordinator service must be running. The service provides transaction support for Oracle Central Designer database operations.
