System requirements: Client computers
Feature Client requirement
Operating system
One of the following:
  • Windows 11 - 64-bit
Processor
Dual CPU Core i3, 2 GHz or higher
Display
  • 1024 x 768 or greater resolution
  • 256 or more colors
To avoid display issues in Oracle Central Designer, Oracle recommends that you do not set the Windows display size setting to Medium - 125%.
Memory
Minimum: 4 GB
Recommended: 8 GB
If the computer has 512 MB or less, you cannot install the client applications.
Disk space
In addition to the space required for the operating system:
  • Approximately 150 MB for both the Oracle Central Designer software and Oracle Central Designer Administrator software
Software
  • Adobe Acrobat Reader 9 (for documentation)
  • Microsoft .NET Framework 4.6.2 and above.
  • Microsoft Edge 114.0.1823.51 or higher
    Edge version 79 or later requires enabling ClickOnce. For more information, see Enabling ClickOnce support for Microsoft Edge version 79 or later in the Installation Guide.
Bandwidth between the application server and client computers
Minimum: 1.5 Mbps (T1)
Recommended: 5 Mbps
