Oracle Life Sciences InForm to Oracle Argus Safety
- About the Oracle InForm to Oracle Argus Safety integration
With this integration, critical data about Serious Adverse Events (SAE) is automatically sent from Oracle InForm to Oracle Argus Safety. - Step 1. Preparation
Ready to set up this integration? Here’s what you need first. - Step 2. Create an SFTP credential key
Clinical One Digital Gateway uses a SFTP credential key to place E2B+ R2 files on the Argus SFTP server. Before you create your SFTP credential key make sure you have an account for the SFTP server. - Step 3. Create an integration group for the Oracle InForm study
For every Oracle InForm study that you integrate, you typically have at least two integrations: a test integration and a production integration. Integration groups are a way to keep integrations grouped by study so that you can easily find and manage them. - Step 4. Download the Oracle InForm to Oracle Argus integration template
The integration template has most of the information and settings you need to set up this integration. Download the template and then you only need to add the specifics for the study you are integrating. - Step 5. Create a test integration
Because you’ll want to test the integration before using it in production, we’re going to first update the template file to create a test integration. If all goes well during testing, we will later update this file to create the production integration. - Step 6: Create the production integration
You're almost done. You're going to download the integration file you set up and tested, update it for production, and then use it to create the production integration.
Parent topic: Available integrations
