Administration Guide User management Create and develop user groups Add users to user groups in Oracle DMW Add users to user groups in Oracle DMW Select Security from the Navigation menu in the upper right corner of Oracle DMW. The page refreshes to display the Security interface. The Roles tab is selected by default. Select the User Groups tab, located at the top middle of the screen. Search for the user group you plan to modify and click it to select. Tip:Click View All Assigned Users from the Actions menu above the search function to view the individual users already assigned to the User Group. Selecting a User Group from the left panel displays the Roles currently assigned to the User Group. To add or remove Roles from the User Group, click Manage Roles in the center panel.The Manage Role Assignments panel displays on the left. Select the checkbox next to the Role name to add it to the User Group. De-select the checkbox to remove the Role from the User Group. Click Save to apply the updated Role assignments to the User Group. Select a Role from the center panel.The Assigned Users panel on the right displays the users currently assigned to the Role within the User Group. Click Assign Users in the right panel.The Assign Users to [Role] panel displays on the right, showing all available users with a search function on top. Use the search function to find individual users and select the checkbox next to their user name to add them to the Role within the User Group. Click Save. Parent topic: Create and develop user groups
