Administration Guide User management Create and develop user groups Create user groups in Oracle DMW Create user groups in Oracle DMW Select Security from the Navigation menu in the upper right corner of Oracle DMW. The page refreshes to display the Security interface. The Roles tab is selected by default. Select the User Groups tab, located at the top middle of the screen. Click Add, located above the search function.The Add User Group panel opens on the right. Enter a User Group Name and a Description in the blank fields. Click Save.A confirmation dialog window is displayed confirming that the new User Group has been created. Use the search function in the left panel of the page to find your newly created User Group. Click the User Group name to select it. Click Edit above the search function in the left panel.The Edit User Group panel displays on the left side of the page. To make enable the new User Group, select the Active checkbox. Click Save. Parent topic: Create and develop user groups
