Access Data Management options
  1. If not open already, click Home. Home in the navigation bar to open the Home page and select a study from the Studies panel on the left.
    For details on selecting a study, see Select a study from the Home page.
  2. Click Data Management. Data Management in the navigation bar.
  3. Do one of the following:
    • To view data and create discrepancies, click Listings. To see custom listings or validation check (VC) listings, scroll down the left panel and expand a data model.
    • To review and act on discrepancies, click Discrepancies.
    • To view how the data flows between the input model and the target model, click Data Flow. For example, a flow diagram shows the mapping between the models and indicates the success or failure of the data flow. It also indicates any warnings within the flow.
    • To create or manage custom listings, click Custom Listing Manager.
