Select a study from Study Manager
If not open already, click
Study Manager in the navigation bar to open the Study
Manager interface. If you have already selected a study from the Home page,
the selection carries over to Study Manager.
- To select a new or different study, do one of the following:
- If you see the study you want listed in the Studies panel, select it.
If you do not see the study you want, find it through the fields in the Studies panel:
Select the category for the study from the drop-down list of the first field (top of the Studies panel).
Type all or part of the name of the study in the search field.
Press Enter or click
Search.
The system displays all studies that contain the string you typed.
Tip:
To clear the search filter, click the
Remove filter -
Select a study.
The next time you log in, the system displays the last study you worked on. You must select it to work in it.
Parent topic: Basics
