Customize the listings view
You can hide, pin, or reorder columns on the listings interface by using Table Settings function. Additionally, you can adjust the width of the Listings/Filters panel to view longer table names by clicking and dragging your cursor.
Click Table Settings and select Open.
Once the Table Settings box has opened, you can customize the grid in the following ways:
  • Reorder columns: You can reorder columns by changing the row numbers in the Row column, dragging the column rows to the desired location by using the drag and drop function Drag and drop row. at the beginning of each row, or clicking the directional arrows Move row up, Move row down. at the end of each row in the Order column.
  • Hide columns: Select the checkbox in the Hide column.
  • Pin (or freeze) columns: Select the checkbox in the Pin column for columns you wish to have fastened to the left side of the grid when you horizontally scroll.
Click Apply to save your changes and close the Table Settings dialog box.
Tip:
To remove all changes you've made to the display of the grid, click Table Settings again and select Clear.
