Validation check listings
Validation check listings show records that include a discrepancy identified by a validation check.
  1. After you select a study, click Data Management. Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Listings from the drop-down menu.
  3. Expand VC Listings (Validation Check Listings) at the bottom of the left panel. Then, expand a data model from the list.
    • To locate a listing, enter part of a listing name in the Search field and click Search. Search.
    • You can choose to show disabled listings by selecting Show disabled VCs. Oracle DMW disables listings if they read from a table that is not used in the study.
  4. Select one validation check in the batch to see:
    • All records with discrepancies identified by the validation check.
    • Any other discrepancies on the records.
    If someone fixed a data item and closed the discrepancy, you cannot see the record.
Validation checks run in batches as configured in the Home page.
