Remove a flag
  1. After you select a study, click Data Management. Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Listings from the drop-down menu.
  3. Expand Default Listings listings in the left panel. Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. Select the row with the flag by clicking the arrow icon at the beginning of the row (first column).
    Tip:
    To select multiple records with flags, press the Shift or Ctrl key while you select records.
  6. Right-click and select Show Flags. The Show Flags dialog box opens.
  7. Select the flag you want to clear and click the Clear Flag icon Shows trash can iconon the right.
    You cannot remove flags assigned in InForm. InForm flags use a prefix of Inf_.
  8. Click OK.
